33" with stock suspension???
Old 12-13-2010 | 11:45 PM
mrfeti's Avatar
Question 33" with stock suspension???
I've got a 2000 4runner 4x4 with stock suspension and no body lift. I'm om the market for new tires and I'd like to throw 33" on there, but I'm not sure how it will fit without a body lift... any suggestions? I've got 31's on there now and it looks like there's plenty of room.
Old 12-15-2010 | 11:52 PM
kball's Avatar
Member
Everything I've heard says they won't fit. To fit 33's you'll need a suspension lift and a body lift and probably some pounding and trimming.
Check out this link. It should have all the info you'll need.
http://www.toyota-4runner.org/3rd-ge...tion-faqs.html
Old 12-18-2010 | 12:03 AM
mrfeti's Avatar
Thanks for the link. There's a lot of good info on there! Any idea what the biggest tire size is that I can fit on a 2000 with stock suspension? If 33's don't work I think the next size down from that is the 265/75/R16 which comes out to be about 31.5 inches...
Old 12-18-2010 | 10:33 AM
kball's Avatar
Member
Yes the 265/75 16 should fit. It's generally thought of as a 32" tire even though depending on the brand of tire it's usually a little under 32".
So unless you have a lot of spring sag the 32's should fit.
It's kind of funny how much more work needs to be done to fit the 33's but I guess that's just what happens when you hit the limit...
Old 12-31-2010 | 11:56 PM
mrfeti's Avatar
Just put the BFG AT's on in the 25/75/16 size... Looks GREAT! Fills the empty space perfectly and they don't rub! Pics to follow soon!
  #6
Old 01-04-2011 | 09:01 PM
kball's Avatar
Member
What size is that again? You left out a number. 265? 285?
  #7
Old 01-05-2011 | 07:45 AM
mrfeti's Avatar
My bad... they were the 265/75/16... they look great. Ill try to post pics soon. Hopefully replacing the shocks and springs this week
  #8
Old 01-05-2011 | 08:38 AM
kball's Avatar
Member
Cool, that's my favorite size for these trucks. I'm going to put a lift on mine eventually and I'm still going with that size.
  #9
Old 01-08-2011 | 03:27 PM
jtimports's Avatar
It takes a 3-4in lift to fit the 33s properly. Im personally not a fan of the body lift but to each their own.
xxtreme
08-22-2012 09:13 AM
kasko
10-20-2010 10:37 PM
Tustin4R
08-21-2008 01:25 AM
eastcoast
04-05-2008 06:41 PM
eastcoast
03-16-2008 10:59 PM
