Timing Chain Cover Leak
New member needs help!!! I just picked up an '87 with the wonderful 22RE. It has 175k on the motor, but the timing chain was replaced about 5k ago. The problem is, the yoho that did it evidently didn't do a good (or the right) job of sealing it. It now leaks like a sieve.
Can anyone tell me a plausible solution that will work to fix a timing chain cover leak other than the major involvedprescribed fix that requires removing everything except the kitchen sink? Any help would be great.
