THROTTLE POSISTION SENSOR HELP!
Old 10-28-2006 | 07:35 PM
aarontml's Avatar
Default THROTTLE POSISTION SENSOR HELP!
SO I JUST BOUGHT A 90 RUNNER WITH 3.O ENGINE. IT RAN GREAT FOR A COUPLE OF DAYS THEN I NOTICED THE IDLE WILL JUMP ABOUT 500 RPMS WHEN HOLDING STEADY SPEED ABOVE 35 MPH. I WAS TOLD IT WAS THE TPS. I CHANGED TPS THEN TEST DROVE AND IT SEEMED TO FIX FOR FIRST 5-6 MILES THEN STARTED DOING IT AGAIN. DOES THE TPS HAVE A CERTAIN WAY TO BE ADJUSTED. OR SHOULD I BE LOOKING INTO SOMETHING ELSE. PLEASE HELP. AMANDA
Old 05-05-2007 | 12:36 PM
jawalker1106's Avatar
Default RE: THROTTLE POSISTION SENSOR HELP!
Hi, yes it has to be set up.you will need to get a manual that will explain the proper procedure, you will also need to have an ohms meter to set it up.
wareagle0823
01-22-2014 10:41 PM
Ray Turner
06-20-2012 11:38 PM
gweelie
06-08-2010 06:56 PM
logg_1414
12-02-2009 02:16 PM
blue 89
12-16-2005 12:49 AM
