Rear drive shaft length for '96' ?
Hello,
I am trying too find out about how long the rear drive shaft is on a 96 4Runner 4x4, 6cyl, auto trans. Specifically, not weld to weld, but overall length from the flat plate that bolts onto the transfer case, to the flat plate that bolts onto the diff. This should be a one piece shaft right? With only the U-joints on the ends and no carrier bearing in the middle? Wierd question, but its a long story.
Thanks, Jeff
Thanks, Jeff
