Problem with TPS code and shifting
Old 03-26-2006 | 02:49 PM
fire3957's Avatar
Default Problem with TPS code and shifting
I recently had some work done to my 4runner and the tech reset the tps code for the truck to shift correctly. Now 4 days later it has gone right back to the same problem. The truck doesn't down shift back to first gear and there for has no go Anyone with any ideas?
Old 03-28-2006 | 02:46 PM
Patrick's Avatar
Administrator
Default RE: Problem with TPS code and shifting
if you paid for them to fix it, take it back..they didnt fix anything, they only reset it...something has to be causing the problem...
Old 05-31-2006 | 04:47 AM
01Runner's Avatar
I had the exact same problem on my Grand Cherokee and I thought it was the tranny until I got the code for a TPS problem (P0138 or something). Knowing that it is generally the sensor itself when these codes come up, I first checked the wires and connector going to the sensor which were ok, and then went and bought a new TPS for about $50, swapped it in the parking lot and took it out for a trouble-free test drive.
FYI, the check engine light will come on when the computer experiences a given malfunction during 2 consecutive driving cycles. When the shop cleared the code(s), they would not trigger the check engine light right away. You probably paid around a fair bit to have your codes scanned and cleared, which takes my $150 codereader about 20 seconds, so tell the shop you don't want to pay for it again (because the light will stay on even after the actual problem is fixed) when you change the sensor, since you already paid for a diagnosis and they fixed nothing.
akempf
10-14-2009 05:18 PM
incarus
03-08-2008 01:51 AM
Bagus912
09-19-2007 06:06 PM
rakesh
07-23-2006 11:18 PM
raycwang
01-12-2005 06:07 AM
