parked was fine/just cranks wont start
Old 01-25-2007 | 11:25 AM
88jrunner's Avatar
Default parked was fine/just cranks wont start
I have a 88 4-runner 22re 5spd fuel inj.Itsat for almost 2 years,then i took few hoses and air intake system and also diconnectet feul filter ,I put all back on ,reached in window and it sarted right up ,drove around yard few timmes and then parked it 2 months later i went to move it and now it cranks but wount start ,Ihave checked fire at 1 plug(it has arc)can hear the click when i turn key on I have ohmed most fuses and have found nothing ...........if i shoot some starter fluid in the trottle body it will try to start until that burns off ?? feul pump?....injectors//.....not depressurizing fuel sytem before unhooking gas line??ANY HELP/ADVISE IS GREATLY APPRECIATED
Old 07-15-2009 | 01:38 AM
87Auto's Avatar
Super Moderator
Default Same Thing Here
I am having the same exact problem.
1987 22RE 4Runner.
It has been sitting for a year or two. Occasionally I would fire it up (every 3 to 6 months) and it would run fine. But this time I have tried firing it, the motor cranks but it won't fire.
If I spray starter fluid into the intake, the engine will run as long as I continue to spray. When I stop spraying, the engine dies.
I have 'spray ran' the engine for a good 20 to 30 seconds (enough time I would think for the fuel pump to deliver fuel from the tank to the engine) but it still dies.
I am under the assumption it isn't getting fuel.
There is at least five gallons of fresh fuel in the tank.
How do I verify the fuel pump is working?
If it is a faulty (or gummed up) fuel pump, where is it located (in-tank or engine bay), and how involved is it's removal?
Is a gummed up/varnished/jellied fuel pump a likely scenario and if so can it be cleaned or will it need replacement?
Looking forward to reading you responces, thanks for sharing.
Steve
tbone011
03-14-2013 10:49 PM
SPK2075
10-08-2009 02:58 PM
clicheche
12-08-2008 12:14 AM
jjlogue3
11-29-2007 08:51 AM
scott101z
10-15-2006 06:54 PM
