major idle problem..help!
Old 12-01-2009 | 04:52 PM
logg_1414's Avatar
Default major idle problem..help!
so i have a 93 v6 and every time i push the clutch in while driving or coming to a stop the idle wont catch @ 750-1000rpm on its way back down. instead it starts fluttering between 100-450 for maybe 5-10sec without dying and then bumps itself back to normal idle. when i jump the terminals the timing doesnt change at all. i checked the ecu for codes and the only code that pops up is a tps sensor circuit. ive changed the tps and adjusted it properly. i even had it adjusted again by a shop and the same thing keeps happening. i need serious help on what this could be. thanks for your time.
Old 12-02-2009 | 02:16 PM
logg_1414's Avatar
no thoughts huh?
gweelie
06-08-2010 06:56 PM
neelsonwheels
06-11-2009 08:19 AM
skip3920
04-07-2008 07:12 PM
Kevdog
12-08-2007 09:59 PM
blue 89
12-16-2005 12:49 AM
