Keyless entry remote programing
Old 01-24-2007 | 02:33 PM
HellsetH's Avatar
Super Moderator
Default Keyless entry remote programing
Does anybody know the programing sequence for programing a keyless entry remote on a '99 4Runner?
Old 02-05-2007 | 02:01 AM
jw's Avatar
jw
Super Moderator
Default RE: Keyless entry remote programing
I ran across directions to do this somewhere on the internet a while back and printed them off. I used them for my '99 4runner, and it worked for me. Lots of steps to follow, but read through them a couple of times, then give it a try.
Step 1 - open drivers side door and get in your vehicle.
Step 2 - put key completely into ignition,then pull out.
Step 3- with door open, lock and unlock 5 times on door console (ten clicks total).
Step 4 - close door then open door.
Step 5 - lock and unlock 5 times on door console (ten clicks total).
Step 6 - put key completely into ignition then turn to the on position then pull key out (you will now hear the door locks lock then unlock a couple of times)
Step 7 - now quickly press the lock and unlock buttons at the same time and hold for one second.
Step 8 - then quickly press and hold the lock button for two seconds.
Step 9 - exit car and close the door
After you do this you should hear a beep then your lights will flash. This will indicate that your remote is programmed to your vehicle. Good luck, and hope this works for you.
Old 12-26-2009 | 01:08 AM
DJC's Avatar
DJC
Anybody know how to program an 09 4 runner so you can use the wireless remote to lock/unlock truck while engine is running??
Old 12-26-2009 | 08:24 PM
Atofilt09's Avatar
Be a bit more specific b/c it influences the answer ... which exactly is aftermarket? The remote start and the keyless entry? ... or just the remote start with the OEM keyless entry?
meyerske
11-11-2007 03:21 PM
sameguy
07-09-2006 01:14 PM
redlsd
10-12-2005 09:10 PM
apse04t
09-10-2005 06:49 PM
hounddog
02-08-2005 04:01 PM
