fuel leak HELP!!!
Old 11-14-2009 | 10:36 PM
cody_brush's Avatar
Default fuel leak HELP!!!
i have a 1991 4runner v6 and there is fuel leaking from (what looks like) the top of the fuel tank and it only leaks when it's started? what could it be fuel return line? coroded line? and is there an access panel?
thanks in advance for the advice... i didnt know were to post this
Old 11-15-2009 | 06:35 PM
eurtoe's Avatar
Default Fuel leak
Your fuel leak is provobly coming from your return lines or your fuel feed line. You can access your fuel feed line from the inspection plate under the right side rear seat under the carpet. You can inspect the fuel return line from under the vehicel. Slide under the passenger side and locate the fuel tank. look at the top of the fuel tank and you will see two small rubber hoses connecting to the fuel tank, these are your fuel return lines.
Hope this helps.
SPK2075
10-08-2009 02:58 PM
craigatkins
07-16-2008 03:50 AM
AK 4Runner Guy
04-17-2008 03:22 AM
craigatkins
03-27-2007 01:49 PM
