Dip in RPMs while braking
Old 02-15-2010 | 11:39 PM
Badwolf's Avatar
Default Dip in RPMs while braking
Hi all.
I have a 1990 3.0 5-speed - I've noticed that when braking, the engine will sometimes dip in RPM (from about 1070-1100 RPM rough idle) to about 800 RPM and then it goes right back up again. I know the idle seems high, but I don't have the time or money to start messing ECMs for my truck that is otherwise running fine.
Anyway, it's just a temporary blip - as if fuel was being cut off for a split second. I don't think this is the case since the fuel filter was replaced about 2000 miles ago, and it only happens when I apply the brakes.
Weird.
Any ideas about where I should look and whether I should be worried?
Thanks.
- Paul in AZ
Old 02-23-2010 | 09:50 AM
danno1100's Avatar
Super Moderator
It might have something to do with your powerbrake booster. As you know vacuum is supplied to the booster from the engine to make braking easier and sometimes they may develop a pinhole leak and when the brakes are depressed will cause a slight leak which will cause the engine to raise or lower slightly. good luck
Old 02-23-2010 | 12:20 PM
danno1100's Avatar
Super Moderator
totheriver
02-19-2015 09:32 PM
Blueaussie001
08-05-2013 03:59 AM
Juneau
11-30-2006 06:18 PM
runmgh
08-04-2006 09:46 PM
dwarren
12-20-2005 04:05 PM
