When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
im not real sure man but i think if u pull the hot terminal off for about 3 to 5 min it should reset itself. but you may want to get a second opinionon that
this reply may be a little late but all you have to do is pop the hood and in the front right hand side is a black fuse box.Just pull the 15 amp fuse for the EFI for 15 seconds and plug it back in.
