Bent sway bar end links
I have a 1999 4Runner. I installed an Addco front and rear sway bar. I now hear an occassional
"clank" from the front end when transitioning simple, low gutters in front of my driveway. I can see
NO mechanical interference. The sway bar links are bent (slightly). Vehicle drives straight and true.
There is no lift on the vehicle. I can try a thinner set of bushings. I can't try a thicker set because the
threads on the stock end links won't allow it.
Any thoughts ?
Any thoughts ?
