ADD 4WD issues
Old 11-20-2006 | 11:21 PM
Serialthrilla's Avatar
Default ADD 4WD issues
I just got myself a 90' 4 runner 4x4 with the ADD system. When I shift into 4HI the ADD system will engage but the cars feels like its really bogging as soon as I left off the gas or clutch in, so much it will come to a complete stop somewhat abruptly. Also, if I go back into 2HI the ADD remains engaged and still bogs, until I come to a stop and reverse about 1ft, then the 4wd light will go off and I can drive in 2wd mode without bogging.
This is my first truck nevermind yota truck, is this normal? I thought the ADD should disengage when I go back to 2HI again, not only when I go in reverse reminiscent of pre89 auto hub days.
Old 12-31-2006 | 03:12 AM
4mud's Avatar
Default RE: ADD 4WD issues
I have a 90' 4 runner 4x4 v-6. I am not wanting to sound stupid but what is a ADD system?
Old 12-31-2006 | 05:08 AM
Kamakura Kid's Avatar
Probably automatic disconnect driveshaft, something like that. Some 4WDsystems have permanently engaged hubs and the front driveshaft (or halfshafts) disengage(s).
Old 12-31-2006 | 05:10 PM
Katsu's Avatar
Check the alignment of your transfer case and check the oilin the case and the front diff. It sounds like you're bogging down from the 4WD catching and getting stuck from poor lube.
acsimpkins
09-10-2009 05:17 PM
MHartley
03-30-2009 10:12 PM
1998v64wd5spd
04-11-2008 01:44 AM
Jerreldulay
12-09-2005 04:43 PM
HRunner
04-20-2005 02:42 PM
