99 4Runner Miss
Old 06-11-2012 | 10:19 PM
Smitty19994Runner's Avatar
Question 99 4Runner Miss
I need help with a miss I am having with my 1999 4Runner, v6. The miss is more apparent when I let off the accelerator around 45MPH. I have changed the following; fuel pump, fuel filter, air filter, timing belt, plugs, plug wires, boots, water pump, thermostat, and I have cleaned the MAF sensor. There are no codes showing. The problem started about two years ago with a very faint miss and has progressed to a very hard miss almost to the point of the engine dying at about 45mph. Any ideas, as you can tell I am performing engine diagnosis by parts replacement and it is getting expensive. The last two items to be replaced besides the vehicle is the coil packs and the injectors. Again there are no codes so I am leaning towards injectors, any best guesses out there?
Old 06-16-2012 | 05:44 PM
Default Follow-up
I have now changed the Coil Packs, injectors, throttle position sensor and plugs again with double grounded plugsas recommended. Still have the miss at about 1500 rpm. whether driving or setting still. I am now going to have to sell the vehicle or blood to get it fixed. Any ideas out there would be so appreciated.
Old 07-15-2012 | 11:23 AM
eDiaz's Avatar
have u tried distributor cap and rotor? i had the same prob yrs back and tht fixed it
Old 09-25-2012 | 03:03 AM
jimmy45's Avatar
Nice post-------------
SIRunner
11-02-2013 06:32 AM
rc14
09-28-2012 10:55 AM
cobhobaroblobie
05-03-2012 07:27 PM
bdavis44
10-11-2007 07:28 AM
ja7369
05-12-2007 10:10 PM
