98 Runner rear Axle seal.. Help
Just found out the rear axle seal in my Runner is leaking[:@] I am more than sure I an do the work but dont wanna mees anything up I dont need to. Can I get any pointers, here is what a friend told me to do. Remove tire, and brake drum. remove the shoes and the brake piston (rplace these) Then from the rear side, remove the four bolts and slide the axle out. there are two sets of seals to remove and replace. Never having taken my Runner apart but done it many times on my blazer was told it was different. Any and all suggestions and help cause I need to Get er done. Must drive to New York on Wed morn.
