'87 Electronically Controlled Transmission
Old 12-09-2010 | 10:29 PM
totheriver's Avatar
Super Moderator
Default '87 Electronically Controlled Transmission
Last week while driving on the freeway, my 4Runner started hesitating and then I smelled an acrid odor (something electrical burning). After pulling of the freeway, it continued to hesitate and even died a couple of times. When it died it started right back up. Eventually the acrid odor when away. Now it runs fine except that I have very little power (the transmission shift poinnts are very low) and the ECT switch on the center console has no effect.
I'm assuming that either the ECT switch, or a relay or computer module may have burned up. I haven't gotten to that level of troubleshooting yet.
Has anyone else experienced this?
I have 1987 4Runner, 22RE, automatic transmission.
Old 02-15-2011 | 02:33 AM
Garret's Avatar
Yeah i also think so.
It might be ECT switch that has burned out. Check the ECT switch if it is then replace it.
Might solve your problem.......
Thanks
flat ballery
Old 06-23-2011 | 11:13 AM
totheriver's Avatar
Super Moderator
Red face Problem resolved itself
About 3 months after the problem happened, the ECT switch started working again, and all my shift points are back. I don't understand why.
Old 10-10-2015 | 03:25 AM
Rj0093's Avatar
I would check all your grounds first corrosion is the gremlin in 87 22re's.
871stgen
11-14-2018 04:27 PM
skypilot
11-14-2018 03:19 PM
Nairn
10-01-2011 03:50 AM
johnnyv
12-06-2010 10:38 PM
Kamakura Kid
11-18-2006 01:02 AM
