2002 4Runner Pulling an RV
I have a 2002 2wd with towing vcapacity of 5000# and gcwr of 8800# I am contemplating buying a used travel trailer 26 feet in length that weighs 3800# dry, probably 4200# at the most by the time I load my food, luggage, and miscellaneous items. Any feedback on whether: </P>
1. The trailer is too long given 4runner's short-ish wheelbase.</P>
2. I am pushing the limits of 4runner with the combined weights of loaded tow vehicle and trailer.</P>
3. Does anyone have any experience pulling and RV and how did it go?</P>
</P>
Thanks!!</P>
its going to maxed out you will need a wieght distribution hitch and a brake controller. a tranny cooler wouldnt be a bad idea, still i will be a hell of a load for the 4runner. how sure are you its 4200#s that seems a little lite for a 26' trailer<IMG src=smileys/smiley5.gif border="0">
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
The 400 +/- lbs you plan to add, do add up quickly. Having had a 27ft trailer pulled with a 1/2 ton burban, good luck, especially depending if you live out west. Those hills are tough going up you will probably make it but it will be SLOW 30-35mph on many of them. I live in Oregon and that alone really dampened our outings. I would get a truck with some 4.10's and then go. The mpg will suck towing or not but when towing the hills will not be such a factor to get over. The 4 runner would handle a lower profile tent trailer ok I would think. The tranny cooler and an oil cooler are a must a tranny temp gage is a good idea also. Brake controller a must have along with the load equalizing hitch. Good luck.
