2002 4runner blowing white/blue smoke
RE: 2002 4runner blowing white/blue smoke
Sounds like maybe a bad head gasket. If it has overheated in the recent past it may have wrecked the head gasket. Check for coolant/water in your oil. It might even look like coffee with cream in it in bad cases. Check if it is consuming either oil or coolant, or both. You need to figure out what you're burning and then find out what the cause is.
