2000 4Runner: Accessory Power outlet fuse??
Old 05-18-2006 | 11:04 PM
lopatoj's Avatar
Default 2000 4Runner: Accessory Power outlet fuse??
Hi All
The accessory power outlets, two in the front, one in the rear stopped having power. The cigarette lighter still has power. I’ve checked all the fuses in the fuse block to the lower left of the steering wheel.
Is there another fuse somewhere that I am not aware of? Is it possible to have opened a wire somewhere in the wiring harness?
Any ideas, tips, help? Or should I break down and take it to the dealer????
Thanks
Jerry
Old 05-21-2006 | 07:50 PM
rakesh's Avatar
Default RE: 2000 4Runner: Accessory Power outlet fuse??
SHOULD BE EASY FIX. THERE MIGHT BE ANOTHER FUSE BOX UNDER THE HOOD.
FIRST MAKE SURE THERE ISN'T ANYTHING STUCK IN ANY OF THE 3 SOCKETS (COINS, METAL,ECT.)
USE A MULTIMETER TO TEST EACH FUSE. CHECK EVERY FUSE.
IS THERE ANY AFTERMARKET ACCESSORIES IN THE VEHICLE?
Greasemonkey88
09-11-2013 03:11 AM
robertsb
08-17-2010 01:28 AM
blandry
12-06-2008 03:14 AM
nava2468
07-24-2008 01:57 PM
JamesG
08-22-2005 07:29 PM
