1995 4 runner Quit and Wont start HElp
I bought a1995 4 runner the other day and it was running perfectly for 2 days. Suddenly while driving it just quit running and will not start. There were no sounds or warnings. It just cranks but won't fire up. The plugs are getting spark and the fuel pump seems to be working but maybe weak. I did change the fuel filter as that looked pretty well shot. Still it won't Start. I really need these wheels to work.. Help!
RE: 1995 4 runner Quit and Wont start HElp
that sucks, I would say check vaccum lines, and then just start troubleshooting. Get a manual if you need to, replaced the cheap parts first. It could be something as cheesy as the EFI relay, but without me, youor a shop troubleshooting there is no way to just say "OH YEAH, thats it"
is it a quick turn over?almost like it doesnt have compression?if the plugs are getting fire check our ignition fuse it is located under your hood on the passenger side it is a 30amp fuse i have had one of those things pop and it just turns over and over.let me know what you find out i have a couple other things you can check
