1989 4runner
1989 4runner
ok guys i have a few questions....i have an 89 4runner sr5 with the v-6 and auto tranny. i want to do a solid axle swap and change transfer case to a gear drive. the front axle and t-case i have is out of an 83 model. is this swap feasible, and for the transfer case what will i need to make the swap? thanks
RE: 1989 4runner
thanks. i found out that the donor vehicle is a '79 model. i can make the axle swap, i just need to know about the transfer case. the motor was a 20r. just ned to know what all i would need to use this transfer case with my v6 and automatic tranny.
RE: 1989 4runner
Check out advanced adators They make all kinds of stuff Tey even make addaptors to drop a small block chevy
In it give em a call
more smileys..
Give them a try They will most likely have a answer or teel ya some one WHO DOES
more smileys..
RE: 1989 4runner
thanks again. i plan on dropping a small block in it this fall. curious to see how the v6 does, it has been completely rebuilt and has only about 5000 miles on it. who knows, might even be worth something to someone that wants a low mileage v6 with an auto tranny and gear driven transfer case all in one package!
#6
RE: 1989 4runner
well, i have a 1990 4runner and am in the process of making a solid axle swap. i know its real hard but i think i got it. my question isshould i custom build some new driveshafts? i dont want to have to replace u-joints all the time
#7
RE: 1989 4runner
1990stock, i'm sure you would have to get a new driveshaft, as for the swap being hard, yours may be a little more tricky than mine only because your gen 2 never had a solid axle under the front. i think 84's to 89's were that same as in usind the same frame and other stuff.
GeorgiaTiger
07-31-2015 10:37 AM
