05 Cargo Net
05 Cargo Net
<FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>Hello:</FONT></P>
Hopefully a silly question, BUT...I just picked-up an '05 V-8 Sport Ed 4Runner. I have a cargo net...it's easy to see how it clips-in near the rear seats, but I can not find any anchors for the 4 loops on the opposite side of the net. How do you attach these things? Thanks!</P>
05 Cargo Net
im sure that the instalation of the cargo net would be in the cargo net area, or in the owners manual. if not, i would go to the dealer and ask them...for the cost of that truck, the salesman shoudl helop you out!! <IMG src=smileys/smiley1.gif border="0">
05 Cargo Net
Yeah, you'd think, huh? This net even had "instructions" with it...they refer to attaching to "the four hooks at the bottom of the cargo base"...which does NOT lift or remove in this vehicle. I'll figure it out. Thanks!
05 Cargo Net
At the rear of the cargo area on the sides of the interior panel there should be 4knob looking things (2 up high and 2 low). That is where the loops go around. They are not 'D' rings to clip into but rather ***** that the net ends loop around.
05 Cargo Net
Yes...I see the "*****" and the four loops, but the two "inner-most" loops do not reacj when strethced from side-to-side across the back. The D ring parts is pretty obvious, I am still stumped as to how it supposedly works...I guess it could work attching the hooks to the D-rings most forward and then stretching the net BACK toward the rear and hooking the loops...still don't think the inner-most loops will stretch across though. Thanks very much for the thoughts.
carid
04-14-2015 10:50 AM
oriojasjr
06-19-2008 11:05 PM
