00 Climate control lighting
Old 12-21-2006 | 05:54 PM
custom_build's Avatar
Default 00 Climate control lighting
Does anyone know if there is an easy way to get to the bulbs behind the controls, found an article for an older 4runner but it is not the same.
Old 03-16-2007 | 08:37 PM
nawlins's Avatar
Default RE: 00 Climate control lighting
Fellow 4runner: There is no easy way to do this task. In my 1998 everything but the climate control lamp (everytime I drive), comes on until I pluck the panel. Indicating a loose bulb. From experience 1996-1999 'runners are quite similar (in parts) if not identical on inside. Then 2000-2002 years go together. You just have to follow the long drawn out procedure to remove the dash panels/clusters to get there. Good luck. -nawlins
rupenzelleo
08-30-2015 06:17 AM
Bakersfield 12
04-29-2013 01:15 PM
Paulos
01-09-2008 01:58 AM
y2ken
10-18-2007 06:32 AM
gixxho
12-17-2006 02:14 AM
