When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I have had my injector O rings replaced and still have a strong smell of gas and some indication on wet pavement that there is a gas leak, any suggestions.
If you've got wet pavement check above to see if you can locate where it could possibly be coming from. That should narrow it down. You'll just have to use process of elimination.
I would guess its the fuel filter, Same thing kinda happened to me after I had it replaced. If it is leaking, try tightening the bolts on the fuel tubes going in and out.
