whirring bearing type noise
Old 06-08-2009 | 04:01 PM
Gringo's Avatar
Default whirring bearing type noise
Hi All, I've got a 1998 4Runner limited with 137,000 on the clock.
I bought it a few weeks ago and it is like new, the previous owner must have loved it. It has a noise coming from the drive train, a whirring type bearing noise that is approximately twice the wheel speed in frequency and is only noticable in coast, to me it sounds like it could be front diff or something in the transmission, but then it could be coming from the back, its hard to say when your testing alone !
Is there anybody who has heard of this before or who can tell me if its a common problem. If its going to be expensive to repair I'll just turn up the volume on the CD until it drops clean off ha ha
Simon
Old 05-31-2013 | 01:03 PM
klebinek's Avatar
Default Noise from under the gear levers
I think I'm having a similar issue except it got a little louder since I took the video. Please check the video in this link and let me know, thanks much!
http://www.toyota-4runner.org/3rd-ge...ing-sound.html
Old 07-18-2013 | 12:44 AM
tonyscott's Avatar
I had also the same issue about noise. I am hearing a grinding noise coming from under the gear shifter lever. The noise is heard when slowing and turning right and over large bumps. It seems like when force is put to a stop and a right turn this grinding noise is heard. any suggestion?
Car Care
Old 08-05-2013 | 04:02 AM
jtimports's Avatar
U-joints wouldn't do it but worth it to check them. The yoke in the diff or tranny can do that, but usually causing leaking. Its a little weird, I would start with check and inspect since that's free to do yourself and go from there.
ironworker125
04-22-2016 12:15 PM
Shannon190
04-15-2011 07:52 PM
cityokel
03-04-2010 09:31 AM
Simon Chile
01-29-2010 03:59 AM
thaiboxing
06-17-2005 04:58 PM
