Smell From Engine
Old 06-19-2005 | 11:33 PM
Pendragon's Avatar
Default Smell From Engine
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Can anyone identify the problem: when I step on the gas going down the highway, a sulfer/rotten egg smell comes throught the inside air vents (when the fan is on/with or without the air conditioning running)? It rapidly dissipates and does not smell at low or high speeds . . . only when I've stepped on the gas, as I would when passing someone. It's a 2003 V8 4Runner
Old 09-24-2005 | 11:37 PM
trowbridge73's Avatar
Default RE: Smell From Engine
Sounds like your catalytic converter is bad. The smell could be drawn in from under the hood through the cowl.
Old 02-08-2006 | 03:34 PM
mstrat2004's Avatar
I've got the same problem...same setup (V8, 4wd, 2003, 81,000miles) I mostly notice the smell when there is a window open, particularry the rear window, so I leave it shut. It is the Cat. Converter...Toyota has a problem with that as my neighbor complains about his camary doing it as well as his daughter's corolla. 1 good thing I see: if someone's tailgating me I just step on it...they wonder who ripped one!
alpine0000
09-11-2006 10:46 PM
bobusma86
05-07-2005 02:17 PM
twisted
02-10-2005 08:44 PM
Keggo
01-12-2005 06:59 AM
Yamaha+Toyota&#061;F
11-25-2004 01:19 AM
