Setting idle and TPS..
Old 12-16-2005 | 12:49 AM
blue 89's Avatar
Super Moderator
Default Setting idle and TPS..
Anyone give me the "correct" way to do this? replaced the TPS because code was related to it, still had light, messed around with set screws on TB and now it has a mind of its own as to where it wants to idle at. Also, changed out the O2 sensor seeing as how it still had the original in it with almost 300k on it. Run the engine at say 1800-2000 RPM load or no load and the check engine light still lites up !!
gweelie
06-08-2010 06:56 PM
logg_1414
12-02-2009 02:16 PM
Kevdog
12-08-2007 09:59 PM
aarontml
05-05-2007 12:36 PM
blue 89
12-14-2005 11:05 PM
