Replacing main bearings
Old 11-08-2006 | 01:00 AM
Brad's Avatar
Default Replacing main bearings
Just about to replace the main bearings in my 89 4runner 3.0 V6 and seeing if anyone had
any general tips on it. Only one of them is bad on the #4 piston but comes in a set and should
probably replace them all anyway. Haven't taken the bottom of the rod off yet, i got the two nuts
but the bottom is being stubborn on coming off. Are there bearings that are thicker to compensate
for the wear (if there is any) on the crank?
Old 11-29-2006 | 05:12 PM
trojan's Avatar
Default RE: Replacing main bearings
I went thru this a few years ago with another toyota. If its knocking the crank will need work. They use really hard bearings in their engines (thats why they run so long) and the crank will wear with the bearings.
lisam
05-20-2009 04:44 PM
jlsmithivan
04-12-2009 11:11 AM
Ace Callaway
02-13-2008 10:54 AM
Brad
10-23-2006 08:14 PM
Impala
5
08-09-2005 07:11 PM
