CLUTCH???? PLZ HELP
CLUTCH???? PLZ HELP
Just today I got a problem with my clutch, at first i had to push the pedal in further to get into gear. But now i cant get into any gears at all. I dont know if i just have to mess with the freeplay or what. Any suggestions?
RE: CLUTCH???? PLZ HELP
You likely have a loss of fluid in the clutch hydraulicsytem (check your fluid in the small reservoir next to the Brake master cylinder). If the fluid is empty, look under the dash where the clutch pedal attaches to the clutch master cylinder. If it's wet, BINGO, replace the clutch master cylinder and bleed the air out of the system. Don't forget to check the slave cylinder (on the RH side of the bell housing) for leaks. Good luck!
