Blown Head Gasket
Old 10-01-2008 | 07:24 PM
AftRunner's Avatar
Default Blown Head Gasket
Hi all,
I've blown the head gasket on my 91 for the 3rd time, grrrrrrrr [:@]
Is there a type of gasket or special repair procedure that will eliminate this known head gasket issue?
This latest gasket failure was caused by a ruptured radiator hose which caused overheating, so......
Is there a type of radiator hose that will never fail, or at least something better than standard rubber hoses?
Thanks for any help.
Old 10-02-2008 | 12:06 AM
jtimports's Avatar
Default RE: Blown Head Gasket
The 3.0 is just a piece of junk man, its very common. There was a recall, you can check on toyotas webpage or calling them.
Old 12-06-2008 | 02:26 AM
petty's Avatar
Super Moderator
ORIGINAL: AftRunner
Hi all,
maybe your engine is overheating that causes your gasket to blown up. Do you noticed any white smooke coming out of the exhaust pipe? Maybe you need to do a cooling system pressure test to see if there's a leak in the system.
tips to save gas blog.
blue 89
05-29-2009 04:22 PM
WindyCityBen
04-29-2007 04:07 PM
