antenna motor
Old 07-28-2007 | 02:54 PM
bristow's Avatar
Default antenna motor
the motor on my power antenna quit working, the motor runs but the antenna wont go up or down, i have it pulled up
what could be the problem
and what would be a good swap to just a stick antenna that is not motorized
Old 07-28-2007 | 05:07 PM
jtimports's Avatar
Default RE: antenna motor
Sounds worn out..
92 has a none moving antenna, you can put that in, its in the same location.
Old 07-29-2007 | 12:59 AM
bristow's Avatar
i was planning on that
Old 11-15-2007 | 01:03 PM
mdunnrt's Avatar
Does the motor make awful noises when you turn the radio on? I had a similar problem a while back. I thought that I was going to have to replace the whole assembly and someone here tried to sell me the unit for $80. What happens is that the antenna is raised and lowered via the motor and a plastic piece that has grooves on it. The plastic piece is fed through the motor assembly and the teeth on the motor gear push the plastic piece up and down, depending on if the radio is on or not. This plastic part is prone to breaking, rendering your antenna useless.
I bought just the antenna mast for less than $21 plus shipping from: http://www.antennamastsrus.com/Toyot...01996-2002.htm
The mast came with very detailed instructions:
http://www.antennamastsrus.com/Instructions%20Mast.htm
Hope this helps you!
jhugh
05-02-2008 08:35 AM
texas4runner
06-04-2007 10:23 AM
mdunnrt
05-01-2007 02:09 PM
rakesh
05-11-2006 03:19 AM
Jack777
02-01-2005 07:02 PM
