2003 Limited 6-disk cd changer removal
Old 05-04-2007 | 12:23 AM
scrufnut's Avatar
Default 2003 Limited 6-disk cd changer removal
How do you remove the 6 disk cd changer from a 2003 limited 4-runner?
Old 05-05-2007 | 01:26 AM
rakesh's Avatar
Default RE: 2003 Limited 6-disk cd changer removal
TOOLS: GET A COTTER PIN PULLER(ITS A HEAVY DUTY PICK WITH A 90 DEGREE BEND AT END. 10mm SOCKET WITH 10in EXTENDER.
1. REMOVE TRIM PIECE OF CUP HOLDER/POCKET. JUST PULL UP.
2. OPEN STORAGE COMPARTMENT REMOVE 1 10mm BOLT
3. CARFULLY PULL ON CLIMATE CONTROL SCREEN. THEY ARE PRESSURE CLIPS.
4. REMOVE PANEL THAT SUROUNDS RADIO CAREFULLY,PRESSURE CLIPS, USE COTTER PULLER TO GET BEHIND PANEL AND PULL GENTLY AROUND TOP OF AIR VENTS AND RADIO AND ALL THEY WAY DOWN TO CUP HOLDER.
5. REMOVE 4 10mm BOLTS UNDER RADIO.
GOOD LUCK
Pete4542
07-26-2018 02:19 PM
vuhuynh
09-13-2007 12:24 AM
suinat
05-04-2007 12:20 AM
scrufnut
05-04-2007 12:14 AM
eldo4runr
05-24-2005 10:44 PM
